Hey folks,
Just reading up on some things needed for my Leopard and I've read that the amount of ceramic grease needed for the gear box is inadequate. So, searching for more tubes of the stuff and apparently Tamiya has discontinued it. So, I'm wondering if Finish Line Ceramic Grease is the same. It says that there's ceramicparticlesin there, so I'm unsure if Tamiya's uses the same formulation.
<a href="http://www.harborcountrybike.com/FINISH_LINE_CERAMIC_GREASE_2_OZ_TUBE_p/lube1019.htm">
http://www.harborcountrybike.com/FIN...p/lube1019.htm
</a>
Anyone use the stuff?<br type="_moz" />
