Thanks Greg and Gerry!<div>
</div><div>Yeah I was reading through Eric's (Heavyaslead's) very in depth review of the Leo, so that's why I thought that there wasn't enough lube in the kit to do the job properly.</div><div>
</div><div size="2">"3) There was not enough ceramic grease provided in the kit (only two 2oz. tubes are supplied). In my case, four 2oz. tubes were necessary for the main gearbox assembly alone. Additional tubes would be needed for the roadwheel bushings, turret bearings and other gearboxes."</div><div size="2">
http://www.sead.us/kitreviews.html</div><div size="2">
</div><div size="2">But if it's not necessary to add extra lube, then I guess it's not. </div><div size="2">Thanks for the tip fellas!
</div>
