RE: Ceramic Grease
Teflon SEALED bearings dont need grease. That is what I use in my Panther. the teflon is what the seal is made from, so the kit should have all the lube you would need. Except for future inspection and care of the gear box assembly. Then you may want to have some ceramic grease on hand. Karen usually has it instock in the spare parts column for your kit. I dont know what the bag will be called for the LEO but when you get it it will tell you what is what.
