ORIGINAL: zl1wn
CG question.
The manual says 220-250 measured from the leading edge at the root.
However, exactly how do you determine where the root of the wing is, due to the sweep at that point.
Can someone please give me advice as to where I should be measuring to.
I would have thought that the leading edge where the wing joins to the fuz, (which is a sharply defined point) would have been better.
Ross
Ross,
Where the wing leading edge joins the fuz
is the root. What you have thought to be logical, is!
Craig
