RCU Forums - View Single Post - AquaCraft V24 Gas Vee RTR Boat - Is this a good boat.
Old 08-10-2010 | 01:15 AM
  #96
01VIPER27
Default RE: AquaCraft V24 Gas Vee RTR Boat - Is this a good boat.
ORIGINAL: V24 1
Hi boaters, im looking for the best prop for my V24 one , ive had the boat 2 years and run the boat in big water,only problem ive had so far is replaceing the flex shaft other then that its been a reliable boat , anyway looking for the best prop for my boat need a little more speed and lift thanks again
I'm a local, you can get a new flex cable from Radio Controlled Sports as well as the WHH RMB703 or an Octura X470. The best CG for the V24 is where the kill switch is mounted so if you lift your boat with a loaded tank and it dips forward, replace the hard tank with an IV bag and place it under the engine. Happy boating...
