NOT A REPLY
Just try the method on a weed wip...leaf blower...chain saw or any 2 cycle engine you have. You will see it will start & run better. Open your mind. That extra oil & mix will keep the seals pliabe...instead of drying out. It will coat your bearings good with oil mix...prevents rust. It will keep rings loose in ring grove. Or go ahead and shut your engine down & heat will keep baking everything in to stay! Your choise!........
