ORIGINAL: tele1974
I just purchased a Venus II from a club member and I plan to start attempting to make it through the Sportsman sequence. I has a Saito 100 mounted up and the doesn't have the upline pull I thought it should have. So... I just pulled the trigger on a Saito 125. It is only 2 ounces heavier. I haven't read through and I am hoping that the 125 was a good choice for the Venus. I am also wondering what prop you guys would recommend I purchase.
Strat... are you a guitar man?
I think you will be happy with a 14x10 APC pattern prop, and as already suggested the tank on CG and a pump, which for a 4-stroke is the Perry oscillating pump, VP-20 I think.
