Hello Folks
This is my first experience with a pull-pull setup so please be nice
Just finished putting the pull-pull system on the rudder and elevator of my new Morris TopCap ARF.
Using Hitech HS-425BB Servos with Du-Bro Super Servo Arms, nice thin braided cable, and standard control horns.
The cables are tight ... very tight. I trimmed the control surfaces and when I give input into the radio then re-center the sticks, the rudder and elevator are out of trim again. Always out of trim in the direction they are returning from. i.e. ... if i give left rudder then re-center the stick, the rudder is out of trim to the left.
Will this problem correct itself with wind traveling over the control surfaces or will I constantly have to trim the plane in flight?
Please advise.
