The best way I have found is to unhook the linkage at the rear of the plane(ele+rudder) then they will release easily. The other option is to twist the pushrod some and that should release the wire from the CF. Be careful when you do the swap, the brick will go in clocked 180* out.
I need to solder a new servo on my vapor brick
Fern
