RCU Forums - View Single Post - KV85 Conversion
Old 08-14-2010 | 11:40 AM
edoubleaz's Avatar
edoubleaz
Default RE: KV85 Conversion
After seeing the Crusader build I think this thread is bush league but I will press on none-the-less!
This conversion requires a bit of surgery to correctly position the turret forward the 13mm it works out to be in 1/16 scale. As it was originally intended for HL, you must also remove the stepped ring from the Tamiya deck. Razor saw time.
After the ring-ectomy, I filled in the drivers hatch and added a fillet to the engine deck to square off the area where the turret was.
Last step, cut of the Tamiya traverse posts.
ID:	1483788   Click image for larger version
ID:	1483789   Click image for larger version
ID:	1483790   Click image for larger version
