RCU Forums - View Single Post - RCV 120
Thread: RCV 120
Old 08-16-2010 | 08:05 PM
Joe Lott
Default RE: RCV 120
vgless,
Do as Andi says and get your low end needle back to its factory setting. Go strictly by the manual during the break-in period. The engine will run very rough at first, but will smooth out the more it's run. If you used a silicone exhaust deflector, throw it away. They are useless for these engines. The 4 stroke exhaust is just too hot. Your engine should achieve its best performance after you have run a gallon or so of fuel through it.
If I remember correctly, my first hour of run time was a series of short runs (5 min. or so) each followed by a cool-down period. I ran it at no higher than 3000rpm during this time. It would be better if you have a test stand, because the initial vibration will be tough on your plane. Believe me, you will notice the engine "smoothing out" over time. Your muffler will stop vibrating loose (which will happen alot during the break-in period). Keep an eye on your crankcase vent tube, specifically the color of the oil being ejected from it. At first it will be dark grey-to-black. As the engine components become seated, the oil coming from the tube will clear up.
The low end needle on my 120SP was spot on from the factory, with no adjustment necessary. Mainly, you need to get the engine running smoothly before worrying about the idle. If it is at the factory setting, you will be ok for break-in purposes.
After that initial hour of break-in, I started opening up the throttle for short bursts and set my high end needle 3-4 clicks on the rich side of max rpm. I still ran the engine for maybe 15-20 minute runs, varying the speed from idle to full throttle. BTW, I'm using CoolPower 10%. The engine loves it.
Let us know how you make out.
Joe
