ORIGINAL: Konrad
Yes. I might even say push it as little and try the full wave pipe. When I was making the jump from muffler to pipe there were no 1/4 wave pipes that I knew of. If I could make the adjustment I think just about anybody can. As for tank size are you looking for a 16K RPM set up or a 12K to 13K RPM set up. Is noise an issue at your field?
All the best,
Konrad
Good questions. I am pretty much going at this alone. Not sure where to go. Noise hasn't been an issue, but I want a set up good for that problem. Hence the muffled tuned pipe. I was hoping to get the most out of it I can.
Brian
