Vanguard, I would look at your cooling. I had the same problem, on a Yak, and solved it with baffling. Pe is correct. On a hot day, you have less air, and therefore need to lean your mixture, if anything, but not normally that critical, from day to day.
Check your baffling in your engine Bay.
