RCU Forums - View Single Post - HB .61 PDP
Thread: HB .61 PDP
Old 08-19-2010 | 07:33 PM
  #39
EscapeFlyer's Avatar
EscapeFlyer
Default RE: HB .61 PDP
This is way off topic as the OP is interested in pattern engines!
I don't mind the discussions and rabbit trails so long as the mods are okay with it. I posted these questions for the express purpose that everyone is posting here. I am greatful for all the insight I've been offered. I also enjoy the banter between those here that really understand what they are discussing. It is easy to see that becuase things are being explained in terms I can understand.
Actually, a few other questions I had have been addressed but I've been too embarrassed to ask. Now I am wrapping my head around those things as well.
Please be warned that 80% to 90% of engine troubles can be traced to the fuel, fuel tank and fuel lines!
Wow. I wonder if that is what I've been fighting.
Does a four stroke have more draw than a two stroke? This might explain why I've had better luck with them.
As per the per the SPA- again, trying to ask for help to bring that to this area is like asking for one's firstborn. I refer you to that 40 mile stare again... I like the piped 2 stroke on the front of a pattern ship. It just seems right to me.
Konrad-
With regard to the tank size, this is why I was really contemplating the pump. From my understanding, a 14 oz tank or larger could cause issues with the engine- leaning it out/fuel draw. The whole purpose of the pump is to counter this, am I correct? The fringe benefit to the pump is I can mount the tank further away from the firewall for more consistant flight in duration, which also frees up some room in the area for the front retract.
Going with a 14oz tank, would I be better off mounting a pump?
I realize you addressed this earlier, but it seems you have a better understanding of my goals now. So I hope you do not get frustrated with the reiteration of this question. If you think I would be fine without the pump, and a 14 oz tank, this is good too. I had a 12 oz tank mounted behind this engine with a stock set-up. The flight would consistantly last 10 minutes plus some change. I think I would like a little extra time for the UFO to get her on the deck again.
Brian
