RCU Forums - View Single Post - g-62 syncro spark ignition
Old 04-08-2002 | 11:49 AM
Flypaper 2
Default g-62 syncro spark ignition
Well worth the money. Does all of the above. Does away with the weight of the flywheel. Idle vibration is very low as is the idle speed. Starts very easily. In fact , dont turn it over with the ign on without a good grip on a blade as it can fire .Also gets rid of the weight of the spring starter, although I still use mine for safety purposes I use both CH and Richtmuth Igns.
