RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 08-24-2010 | 10:33 PM
  #1397
tele1974
Default RE: Venus II
Is the Syssa to big for this one Moulder. No place for the pipe. Iam still trying to figuer out what pattern plane I am going to mount it in that isn't going to require a loan.
Iliked the speed of the 14x10 but it the 125 Saito just doesn't have enough torque to pull the upline with that prop. I went to a 15x8 and the rpm's went up to 9000. The uplines are okay now as longs as its spooled up. Its sluggish pulling out of a hover. (Yeah, I know)
My motor is still realitively new. I am only on the 3rd gallon and the last few flights to felt like it was starting to wake up. If thats possible with these motors. Maybe it was just getting lean.
I will move my tank back to the CG and install a pump when I get back from vacation. I am heading to the Wi Dells then to Dave Scotts school for the week. Should be a nice little vacation.
Zedhead, I see that you have you motor mounted vertical. I like it. What RPM's are you getting with that prop. How is the vertical pull with that prop?
