RCU Forums - View Single Post - saludo me presento
Old 08-28-2010 | 02:18 PM
alfredbmor's Avatar
alfredbmor
Default RE: saludo me presento
ORIGINAL: jmgm
saludos ¿cual seria el motor bateria y control de velocidad para poner en el transformer 4 en 1 ? para pasarlo a electrico gracias saludos.
Took from the multiplex web page:
-Tomado de la pagina de Multiplex en internet:
The perfect choice of power for your MiniMag or Easy Star is our MiniMag / Easy Star Power Pack. Optimized to get the most out of your model, the Power Pack comes complete with a High Performance Brushless Motor, Speed Control, Prop and Hub. This Power pack is designed for 3S 1600-2500 mAh LiPo battery packs.
MiniMag / Easy Star Power Pack Includes:
* Himax 2815-2000 Brushless Motor
* 5.5 x 4.5 APC Prop, Hub and Driver
* MULTIcont BL-17 ESC
Motor Specifications
Motor Type Brushless In Runner
KV 2000
Watts 275
Size D x L 28 x 38 mm
Weight 86 g
Speed Control Specifications
Max Cont. Current: 17 Amps
Voltage Range: 6 - 15 Volts
Max Battery 3S LiPo
BEC Current 3 Amps
I believe that it will help you getting start.
-Creo que te ayudara a comenzar.
