ORIGINAL: jmgm
hola this is my project is a coach advanced thanks (in construcction)
I can't get a good visual from your fuselage but I would say that you cut the dowels where the wing should be fastened by rubbing bands, that is not like it should be. Please tell me if you cut them.
-En la foto no alcanzo a distinguir si has cortado los dowels de madera que se insertan en el fuselage y donde pondras las ligas para sujetar el ala.
Si las cortaste esta mal. Los dowels deben de ir de una sola pieza y atravezar el fuselage de lado a lado.
Por favor dime si las cortaste, es algo que aun se puede corregir.
Alfred.
