RCU Forums - View Single Post - world models intruder
Old 08-30-2010 | 04:56 PM
  #106
Balsawings's Avatar
Balsawings
Default RE: world models intruder
Cees,
You've got it backwards. Look at any good set of plans that shows incidence, you'll see negative is leading edge down.
The reason for the +.3 wing and -.3 on the stab is simple. A truly symmetrical wing will not fly at 0 degrees. It has to have a positive angle of attack before it will create lift. If you set a plane up 0 - 0 you will have to use up elevator trim to creat the positive angle of attack.
Bob
