RE: Nitro Engine Break In
Really no right answer as there are several break in methods....I dont see the need in running 3 tanks with wheels off the ground. If you are going to use the manufacturers recommendation, I personally would interpret the 3rd tank as a low rpm (1/4 throttle) run with wheels on the ground, then follow directions from there. Most importantly is to let it cool with piston at BDC after every run.
