Nitro Engine Break In
Old 09-02-2010 | 07:55 AM
Default Nitro Engine Break In
Ok just want to know how many tanks of fuel do i need to run with the wheels off the ground for break in. My manual says 3 tanks with wheels off the ground then contradicts its self in step 2 of break in proccess where it states on the 3rd tank do low rpm boxes.
how many break in tanks do i need to run before i can go balls to the wall?
o the truck is a Savage X 4.6 all stock
Old 09-02-2010 | 08:12 AM
My Feedback: (12)
Default RE: Nitro Engine Break In
Really no right answer as there are several break in methods....I dont see the need in running 3 tanks with wheels off the ground.  If you are going to use the manufacturers recommendation, I personally would interpret the 3rd tank as a low rpm (1/4 throttle) run with wheels on the ground, then follow directions from there.  Most importantly is to let it cool with piston at BDC after every run.
Old 09-02-2010 | 08:20 AM
how do you know if piston is at BDC?
Old 09-02-2010 | 08:56 AM
sheograth's Avatar
Moderator
I've developed my own pattern over the years. I generally idle through a tank, then run it with very varied throttle for a couple more. With proper engine maintenance it seems to be working fine for me.
Old 09-02-2010 | 06:09 PM
ok 2 tanks just idling off the ground 2 tanks doing low rpm circuits. Is this thing broken in now? Can i go full throttle and tear it up with my next tank?
Old 09-02-2010 | 07:45 PM
SyCo_VeNoM's Avatar
ORIGINAL: trickle007
its not broken in yet IMO most instructions tell you to take it easy for 10 tanks
up till the 10th 12th tank be moderate and only do full throttle blips(5-10 seconds)
To get Bottom Dead Center heres what I do
Take out the glowplug
Shine a light down the hole
rotate the flywheel till the piston is perfectly at the bottom
put a mark on your flywheel at the top
after every run make sure that marks at the top when the engine is cooling
That will help you get the most like out of your engine.
Old 09-02-2010 | 09:13 PM
thanks for the replies i will take it slow the next 6 or so tanks
