RCU Forums - View Single Post - Designing a new pattern model
Old 09-04-2010 | 09:49 AM
  #151
MarkGrabowski
Default RE: Designing a new pattern model
ORIGINAL: Alex Voicu
Hi Claude,
At the moment i am only able to work during weekends, which makes the progress a little bit slow.
Anyway, sheeting the fuselage with balsa is a tedious job and i think it took longer then assembling all the lasecut parts. I tried different techniques, like planking (covering with narrow balsa strips) and bending balsa with water just to see which one works best. Pictures will follow in a week or two.
The fuselage is 160mm wide and 345mm tall, but i've been playing with a slightly different canopy shape that will reduce the height of the fuselage to 338mm. The rudder is about 400mm tall.
Alex, is the balsa you used on the top, curved parts of the fuselage the same thickness as the flat sides? If not, how thick is that balsa compared to the sides...
Mark
