RCU Forums - View Single Post - Designing a new pattern model
Old 09-04-2010 | 02:46 PM
  #152
Alex Voicu
Default RE: Designing a new pattern model
ORIGINAL: MarkGrabowski
Alex, is the balsa you used on the top, curved parts of the fuselage the same thickness as the flat sides? If not, how thick is that balsa compared to the sides...
Mark
Hi Mark,
Initially i used 1.5 mm balsa for all areas. Anyway, i recently stripped all the balsa sheeting and re-covered the whole fuselage. Flat sides are still 1.5mm, but this time i used 2mm balsa for planking the curved areas to compensate for the final sanding.
ID:	1495206   Click image for larger version
ID:	1495207   Click image for larger version
ID:	1495208   Click image for larger version
