RE: Sig Kadet LT-25 build.
Not yet. There is a woodworking shop close by which you pay per hour to use all there equipment. They have everything. Thicknessers, planers, lathes, biscuit cutters, table saws, spray booth etc etc etc. So I thought I'd splash out and go and make a decent bench that will fit nicely into my shed but also I have put some heavy duty castors on it so I can roll it around and work outside when the weather is good. I will post a pic when I'm finished if you want. It's a pretty basic design but it will be strong and heavy. Once I've made the bench, I won't have to use the workshop so much.
Size - 1900mm L x 700mm D x 900mm H. Not sure what that is in feet and inches? I made it that size so it would fit nicely between a few things in my shed. Otherwise I would have made it a bit longer but it should fit all of the wings I am planning to build nicely!
