RCU Forums - View Single Post - WING LOADING - (LET'S TRY THIS AGAIN)
Old 09-05-2010 | 10:11 PM
marwen1's Avatar
marwen1
Default RE: WING LOADING - (LET'S TRY THIS AGAIN)
ORIGINAL: Mr Cox
The ''Cubic'' wingload, weight(g)/wingarea(dm2)^3/2, is good guide to how the plane will behave. A number of 4-6 is typical for free-flight, 8-10 is a good sports plane and 12-14 (and up) is warbird territory.
Then you choose an engine to suit. A thrust of 1/3 of the weight is about minimum for sustained flight, a thrust near equal to the weight is fine for sport flight and for 3D you need more power.
It is as simple as that....
ORIGINAL: Mr Cox
Well, my DELTA is 48" for the root, the overall WS is 60", and it weights just over 10 lbs
so, if I look at the R. or L. half it has a 6" clip on the wing tips - making the cverall shape of the 1/2 wing - a screwed up rectangle. I think it's what is referred to as a TRAPEZOID
According to a variety of research - my DELTA is now at 780 sq. in. and just around the 10 lb. area. Accordingly, this all important number is coming in at around "30".
If I were around 1/2 that size - say 36" WS and in the 6-7 lb area. the loading is almost the very same!
A small .40 ENYA i used to have in the late 80's made the 36" version kick out at about 45-+50mph.
This LARGER version of the same plane - as I say - is 60" WS.. I now have a ROSSI .81 DF to power this larger bird.
The DF is for "DUCTED FAN". - with a tuned pipe!
From what I've seen so far, the old ROSSI engines are like running straight TURBO.
Now then, PROPS - I have an 11/7 MASTER AIRSCREW (PUSHER) on it - I also have some smaller ones, too
What to do?
I've run the ROSSI a couple of times but I'm waiting for a solid BULLET for the nosecone. It'll thread right INTO the prop shaft.
Right now, I barely have enough threads to keep it on
marwen1
