RE: ASM C-130 101
Hey Marvin,
Wow the nose gear looks great without the cable set up. On mine i had a couple of rubber bands attached to the middle of the cables
under tension and as the gear came up they pulled the cables away from the gear and cleared it. just one question with the servo
mounted like it is what will you use to pull the rear nose gear close when is retracted.
Also just uploaded pictures of the flaps and slides.
Jerry.
