RCU Forums - View Single Post - JetCat Accessories/RS 232 data cable/GPS, etc
Old 09-08-2010 | 01:49 AM
Carsten Groen's Avatar
Carsten Groen
Default RE: JetCat Accessories/RS 232 data cable/GPS, etc
Joe,
it is correct that you can download parameters from the JetCat ECU with the software from JetCat.
However, I would suggest not to use the original JetCat cable for this, it is way to expensive, and it's a RS232 connector (not many labtop's have RS232 any more). I use this from Digitech: http://shop.jet-1a.com/product_info....oducts_id=1576 much easier as it plugs directly into the USB port
The GPS module works fine, it will show you travelled distance, max speed, max G load (not very accurate as it is calculated) etc.
JetCat also has a Air speed sensor (will show max speed, travelled distance etc)
Values from both the GPS and airspeed sensor will be shown on this module: http://shop.jet-1a.com/product_info....oducts_id=1619 whick can be left installed in the plane
The GPS and airspeed module should be available from JetCat or one of their distributors (I got my GPS and Airspeed sensor from Digitech)
