RCU Forums - View Single Post - 1560 max. Characters including spaces
Old 08-22-2003 | 02:15 AM
Hossfly's Avatar
Hossfly
Default 1560 max. Characters including spaces
Originally posted by EASYTIGER
I notice a certain reluctance to adress this issue. Like pretending not to hear it.
Well, ET, the subject has been discussed somewhere along these forums. You can look it up if you wish.
As usual, your knowledge of history is less than perfect.
>>>>>>>"Horrace was elected once, it was a disaster for us AMA members, and nothing about him has changed since, if anything, it's worse."<<<<<<<<<<
Actually I was elected TWICE, the second time being by WRITE-IN.
It seems, ET, that there are some that disagree with you.
I must say "Thanks to you" for believing that I had the power to enable a disaster for all AMA members. Was that my initiating the action of enabling the Chairman of the Freq. Committee to obtain the FCC's final release of the 50 freqs. still in use today, or is there something else that you may have in mind?
Since you lack the character and intestinal fortitude to stand up and be counted as a real person, therefore I will just ask you if you might be one of those AVPs that got fired for simply using the title and not doing anything for that title. You do sound a bit bitter for reasons known only to yourself.
Yep, ET, you just might be correct. I just might be worse, especially for those that crawl under the rock and strike simply to exercise their tongue.
As good ol' LeMay told us SAC Bomber crews, "Don't bother me with your problems, just show me the results." As a District VP, I will show you RESULTS.
