RCU Forums - View Single Post - JetCat Accessories/RS 232 data cable/GPS, etc
Old 09-09-2010 | 01:15 PM
digitech
My Feedback: (10)
Default RE: JetCat Accessories/RS 232 data cable/GPS, etc
ORIGINAL: i3dm
In all honesty Sandor, that wasnt a very clear explaination - can you clarify ?
come on you must know how to use window$?
my best guess is you plugged the cable and windoze has installed the driver?
go to windows / properties
click on hardware (usb cable must be plugged)
you see in the comport section the cable driver
change that driver and you point it to the jetcat driver *.inf
after this dont let it restart , click on the properties again
go to advanced
change the comport to com 2/3/4/5
after this it should work fine
the jetcat software finds his own comport
OR
plug the cable
go to properties / look for the cable in the comport section
uninstall / unplug the cable
plug the cable / it wants to look for the driver in windoze/update
dont let it instead point it to the place where the jetcat drivers are.
still check the comport if its not to high(>5)
