RCU Forums - View Single Post - Red Wing MX2 Build
Old 09-11-2010 | 12:08 AM
DaleD's Avatar
DaleD
Default RE: Red Wing MX2 Build
Forgot to upload pictures
ORIGINAL: dadavis9
<span style="font-size: 9pt; line-height: 115%">Imanaged to do some additional work last night focussing primarily on the wing servo and aileron control hardware assembly. As Istated previously, Iam using Power HD servos which I installed using socket head screws which reduces the likely hood that I will have a screwdriver slip and puncture the covering.While installing the anodized aluminium control arm to the supplied servo circular control horn I realized only that two of the holes lined up. Itherefore had to bore two holes in the aluminium arms.
The pre-cut slots in the aileron for the control horns were easily identified and once the covering was cut away applying 5 minute epoxy and inserting the horns was as easy as 123. The supplied ball links and push rod was easy to assemble and install despite having to drill the control horns on the aileron and also the aluminium horn on the servo to receive the supplied socket head bolt.</span></p>
ID:	1498645   Click image for larger version
ID:	1498646   Click image for larger version
