RE: world models intruder
Here are a few picture's. Look at the picture's of the Intruder. You can see the one pix, where the wire's were used, the two piece's going to the elevator's, the plastic joiner at the servo end, not used, the wire's are wrapped with wire and soldered together. Look right under the wing bolt's, you can see the tube's. Another picture of DB pushrod's used, different plane.
Also, the aileron set-up, I make my own pushrod's out there, all 440.
There is probably some kind of Chinese rust preventative on the wire's. I stuck those dude's in there, and jimmyed them back and forth about a 100 time's, till they were loose to use in the tube's. The Cub is a bashed Arf, siamesed cowl, Saito twin.
Vince
