RE: world models intruder
NOTE,
While you all are at it, before flying, it would be best to check the covering around the leading edge of the wing and stab. I found out the hard way. That strange buzzing sound at full warp was the covering lifting on the LE edge if the starboard wing. It hasn't flown since.
During the postmortem it was revealed that the leading edge covering on the other wing and the stab were also not stuck and in testing I could not make it stick.
If I ever complete the repair I will wrap the leading edge with clear something.
BTW, good luck matching the orange covering.
AW
