RCU Forums - View Single Post - the Invisible Mini
Old 09-12-2010 | 10:40 AM
  #96
crash bandicoute
Default RE: the Invisible Mini
<span style="font-size: small"><span style="font-family: Comic Sans MS">i got much of the bottom wing done yesterday. i didn't realize how much time it actually takes to get everything perfect. i still need to do the cap strips and the aileron work and cover the center section of the bottom aft edge. i went a little different because of the servos going on the wing panels instead of the center wing.the leading edges are all good. the blocks for the N-struts will still need to be cut out and installed. there's a lot more to this wing than i thought there was, just looking at it. i've decided to see if i can't fit the standard servos in the wing. i think when i was looking at them before i was just looking at the thickness of the wing rib; not with the cap strips installed. if i need to, i will just cut the corner down a tad bit on the mount part of the servo to keep it from jutting out under the skin. speaking of skin, i got the clear and transparent red from towerhobbies the other day and am getting anxious to cover. funny though, last i remember, I HATE COVERING!!! but i'll post pics this afternoon of the wing done up as much as i've got it. maybe get a little more work done on it also; kitchen pass has been submitted. </span></span>
