RCU Forums - View Single Post - ASM C-130 101
Old 09-12-2010 | 05:25 PM
testfly
Default RE: ASM C-130 101
Thanks for the info. I agree it is great to see and share ideas.
I don't mind doing so. I also enjoy seeing what others are doing or have done.
I just finished adding a air compressor to the pushback truck I designed and built.
It was built to pull my models to the flight line from my tralier. I use to pull them with a strap.
But, I am wanting to bend down less and less as I get older.
As it turns out the pushback truck has been a real hit at our field and the guys
really enjoy seeing it in action. In fact i have no problem getting a driver for it.
I am sure the on-board air compressor will put it over the top when they find out about it.
Complete information on the build can be seen at:
http://www.seabreezeparachutes.com/p...ruck/view.html
BTW: Can you list your power setup and props?
Any idea of the amp draw?
