RCU Forums - View Single Post - ASM C-130 101
Old 09-12-2010 | 06:18 PM
Marvinf14's Avatar
Marvinf14
Default RE: ASM C-130 101
ORIGINAL: testfly
Thanks for the info. I agree it is great to see and share ideas.
I don't mind doing so. I also enjoy seeing what others are doing or have done.
I just finished adding a air compressor to the pushback truck I designed and built.
It was built to pull my models to the flight line from my tralier. I use to pull them with a strap.
But, I am wanting to bend down less and less as I get older.
As it turns out the pushback truck has been a real hit at our field and the guys
really enjoy seeing it in action. In fact i have no problem getting a driver for it.
I am sure the on-board air compressor will put it over the top when they find out about it.
Complete information on the build can be seen at:
http://www.seabreezeparachutes.com/p...ruck/view.html
BTW: Can you list your power setup and props?
Any idea of the amp draw?
Hey Testfly,
Sweet towcar we might copy your body on our towcar, hope you dont mind , nice car super heavy we see it is thats perfect for towing and great idea on the air compressor, sweet.
Bob is here next to me states the engines are Chinese engines, he bought them 3 yrs ago they are 600kv equivalent to an eflight 46, 38amps full power per motor, using 4 lipos 5K 4S per motor, 70amp speed controllers, blades are master screw 11x7 plastic 3 bladed
