RCU Forums - View Single Post - converting zenoha 23 to electronic ignition
Old 09-13-2010 | 12:59 AM
airrrace
Default converting zenoha 23 to electronic ignition
Im converting zenoha 23 to electronic ignition using XYZ CDI, where should the timing be set?Is it ok to remove the flywheel to make lighter?are there any web sights showing how to do the conversion?
