RCU Forums - View Single Post - Gas engine parts interchange data
Old 09-13-2010 | 09:07 AM
captinjohn
Default Gas engine parts interchange data
I am starting a new thread Gas engine parts interchange. Some of the first postings may be cut from another thread. It would be good if we could kinda keep the postings to just mainly what parts will interchange form any small RC engine including power product engines like chains saws ect. This thread may take a long time to get all the data others may have... added to it. Thanks Capt,n<hr />
As Kweasel has pointed out - 2 of the engines that currently have the highest "top end power" (Actual useful torque to turn large props and make large amounts of thrust) are both "under square".
Captinjohn, it sure would be an interesting thread. So many engines have such similar dimensions, there is a plethora of useful parts around. some may require very minor mods to make them work well.
Badazzmax - I have recently used the exact same crank as you to replace an "early JC" one. Didn't try the cylinder change out but it sure makes a good idea for obtaining good quality parts for the future.
(Now I wonder what I could use to replace a 28cc crank - shoud I ever need to - might investigate that in the next week or so - not that I need to of course [img]{akamaiimageforum}/image/s4.gif[/img] ).
I wonder if it would also work with the old DL50 bits. I have a couple of very low run time of the "Version one" of those (the one with the weak crankcase lugs) I might have a bit of a play also - like you, I have a few spare crankcases laying around that are not useful for anything else.
