RCU Forums - View Single Post - thunder tiger pros, help
Old 09-13-2010 | 10:59 AM
RussianFlyer's Avatar
RussianFlyer
Default RE: thunder tiger pros, help
I've found that with my TT Pro 46 engines, the needle valve housing has a tendency to loosen up and create an air leak. Double check that yours is tightly screwed in (don't strip it, just verify). The housing is the part that the high speed needle screws into. it also sandwiches the fuel nipple fitting against the carb.
