RCU Forums - View Single Post - transmitter receiver
Old 09-13-2010 | 06:06 PM
CGRetired's Avatar
CGRetired
Default RE: transmitter receiver
Ok, well, the Futaba Skysport IS a 72 mhz system. It is fairly current as far as 72 mhz systems are concerned. It is a single system, meaning no memory or multiple models, ie. no computer power. So, it is for one plane.. or if you want, you can have several planes with the same frequency receiver and set them all up the same. Many of the RTF's came or come with that radio system. I am not famaliar with the Hitec system. Someone else will have to work with you on that one.
Just about any servos will work with this system, so the Hitec servos are fine.
72MHz Channel / Frequency Table
11 / 72.010 28 / 72.350 45 / 72.690 12 / 72.030 29 / 72.370 46 / 72.710
13 / 72.050 30 / 72.390 47 / 72.730 14 / 72.070 31 / 72.410 48 / 72.750
15 / 72.090 32 / 72.430 49 / 72.770 16 / 72.110 33 / 72.450 50 / 72.790
17 / 72.130 34 / 72.470 51 / 72.810 19 / 72.170 36 / 72.510 53 / 72.850
20 / 72.190 37 / 72.530 54 / 72.870 21 / 72.210 38 / 72.550 55 / 72.890
22 / 72.230 39 / 72.570 56 / 72.910 23 / 72.250 40 / 72.590 57 / 72.930
24 / 72.270 41 / 72.610 58 / 72.950 25 / 72.290 42 / 72.630 59 / 72.970
26 / 72.310 43 / 72.650 60 / 72.990 27 / 72.330 44 / 72.670
Hope that helps.
CGr.
