trouble with 2.4 cam
I was wondering if anyone has had any problems using a spektrum dx7 with a 2.4ghz mini cam, I have tried it in 2 different planes and lost control on both ending with crashes. I was under the impression that the dx7 would not pick up glitches that easy, unfortunatly mine did pickup glitches off of the cam, I know this because after repairing my planes and removing cam all was good. Could someone tell me the best cam to use with the dx7
ON, CANADA
RE: trouble with 2.4 cam
I think yours is the first I've heard that has specifically intereferred with the plane causing crash. Generally it affects the video quality. Anyways having both video and control on the same frequency seems to be a big no no for consistency. I would suggest 900mhz system and you'll run into no interference issues.
Ivan.
Ivan.
BC, CANADA
ORIGINAL: mbyers1971
