Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Basic Design Software? >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 12-06-2011 | 05:59 AM
558th_AV8R's Avatar
Default Basic Design Software?
As I "mature" in this hobby, I find myself growing more and more fond of the basic aerodynamic principles/engineering/design that are inherint in RC. That being said, is there any basic CAD software available that is centered on the needs of an amateurbuilder/designer of rc aircraft? I'm not looking to drop major money on some overly sophisticated programjust something that would allow me to mess with basic airfoil shapes, generate a rib set, former set, etc. Is there anything like that out there? Thanks!!!</p>
Old 12-06-2011 | 07:44 AM
iron eagel's Avatar
Default RE: Basic Design Software?
Yes there is, if you check in the scratch build and cad design and the top of this forum there are stickies with just this type of advice...
Old 01-06-2012 | 03:09 AM
There is a free version of Turbo CAD available [link=http://www.rcgroups.com/forums/showthread.php?t=1557294]here.[/link] It's a full CAD program so a bit of a steep learning curve, but it's capable of pretty much anything you'd want to do for model design.
Old 01-06-2012 | 08:14 AM
iron eagel's Avatar
I use turbo cad myself. Using turbo cad and profilie you can do pretty much anything as far as model design...
