Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Canard
Old 12-29-2003 | 09:30 AM
My Feedback: (65)
Default Canard
I'm building a 40 size canard. My ques. is, what happens if I have too much vertical stab.{ about30% too much?} I know, why not make it smaller? Well let's just say there design reasons for making it this way. Roger
Old 12-29-2003 | 07:48 PM
JimCasey's Avatar
Default RE: Canard
Too much vertical stab will cause spiral instability. If you trim for straight and level and let go, the first time the plane hits turbulence the nose will drop and the plane will enter a spiral dive. Unless you plan to fly hands off a lot, it will most likely not pose too much of a problem for you.
Old 12-29-2003 | 08:06 PM
Default RE: Canard
Hi Roger,
If you would like excellent Canard design parameters check the
5/95 Model Aviation.
Can not imagine why you would want 30% vertical stab area, N.G. !!
10% of the wing area is reasonable if the vertical is in the area of the
wing. If forward at the canard, perhaps 7% max.
Good luck and have fun!
Hal [email protected]
Old 12-30-2003 | 08:20 AM
DICKEYBIRD's Avatar
Default RE: Canard
ORIGINAL: Hal deBolt
Hi Hal....are you talking about putting the vertical area up front, forward of the CG? Wouldn't that make it swap ends, like an arrow with the feathers up front? Maybe I misunderstood you.
Old 12-30-2003 | 10:00 AM
My Feedback: (65)
Default RE: Canard
Hal, I know it's not the best design,but because of other [funkie] things I want this thing to do, I am stuck with to much vertical. My question is what to expect? Roger
Old 12-30-2003 | 12:25 PM
Default RE: Canard
Roger;
A good test is to make a small hand launched glider, 12/14in. and see what it does. A good way to find CG. Stab, wing incidence and such things. When it works on the small one it will work on the big one.
Old 12-31-2003 | 01:38 PM
My Feedback: (65)
Default RE: Canard
Flypaper, I'm tired of building on this project. I thought all you smart guys have been there and done that and could help an old man out. I do appreciate the knowledge shared on the forums.
Roger
Old 12-31-2003 | 01:41 PM
PaulSwany's Avatar
My Feedback: (45)
Default RE: Canard
Got that CG problem figured out yet? Milton could probably give you one of those Cox .049's to fly it.... Would definately help you with your nose heavy problem....
Old 12-31-2003 | 01:59 PM
Default RE: Canard
30% isn't all that much larger.... I've gone at least that amount smaller on some planes.. which showed me the original vertical was larger than it needed to be.
With ailerons, it should be controllable.
The biggest problem with canards is the fragile front end. Usually there's a big hunk of motor/firewall to take the "arrivals"...
Old 12-31-2003 | 03:41 PM
BMatthews's Avatar
Default RE: Canard
Do you mean 30% of the wing area or 30% bigger than the 30% of the wing that it should be?
Canards DO require a larger vertical than conventional models do because if the very short moment arm between the aricraft neutral point and the vertical compared to conventional layouts. Chances are what you think is too much is either just right or may not even be enough.
I also second the little all balsa glider for testing. If you can't make a simple profile all sheet tester like this in under 1/2 an hour you don't deserve to own an Xacto knife....
Old 01-01-2004 | 08:04 PM
My Feedback: (65)
Default RE: Canard
What am I thinking, I have 6 Xacto knives so it shoud only take me 5 minutes to builb a handlanch glider.
Old 01-01-2004 | 09:06 PM
My Feedback: (65)
Default RE: Canard
Tall Paul; Thanks for the good information. This thing is a tracktor so the engine and firewall will get there first. My verticals are 15.5% of the wing area and as far aft as possible. It's in the covering stage so it's a little late for major changes. The C.G. came out about .5" forword but I can change it real easy. I'll let you know if this thing works. Dickeybird is in on a lot of the design thinking , so it may do something.
Roger
