Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Downthrust for motor >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 01-23-2004 | 06:28 AM
Ozelot's Avatar
Default Downthrust for motor
I am about to convert a glider to electricity. The glider is the local version of Gentle Lady, (Blue Phoenix for you swedes out there...) with two meter wing span and Clark-Y profile. Do anyone have a suggestion for suitable down-thrust in relation to the wing for the motor?
Jens
Old 01-23-2004 | 08:20 AM
Default RE: Downthrust for motor
IMHO would suggest starting with 3 to 4 degrees of downthrust for a Clark Y.
Let us know how your project turns out.
Regards
Ramrod25
Old 01-23-2004 | 12:23 PM
BMatthews's Avatar
And about 2 degrees of right thrust.....
You'll probably find that the model still wants to nose up with power even with 4 degrees of downthrust. This will be much more noticable if you're using a gear drive system and large efficient prop. If you trim the CG placement using the dive test procedure you'll find the nose up effect may be reduced somewhat.
Old 01-23-2004 | 01:54 PM
Banned
Why not just look up the specs on the Goldberg Electra. I think it has 5 deg down and 3 right, but its been 15 to 18 years since I built mine. (and the motor that came with it was dismally inadequate)
Old 01-25-2004 | 04:18 AM
Ozelot's Avatar
I'll keep you posted when things start to proceed.
Jens
