Go Back  RCU Forums > RC Airplanes > Aerodynamics
 big balance problem >
big balance problem
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
big balance problem
Old 06-01-2004 | 02:38 AM
Dancy's Avatar
Default big balance problem
Anyone know where this thing would have the CG located?
Old 06-05-2004 | 07:53 PM
Spaceclam's Avatar
Default RE: big balance problem
in your mind, fill in the gap in the wing, and then put the cg wherever you put it on a delta wing. (this is not certain but a good guess i will bet)
Old 06-06-2004 | 09:49 AM
rmh's Avatar
rmh
This "design" surel looks familiar - like an old cat that shows up from time to time.
Onething fer shere - if it ever gets into a spiral/spin - be prepared to leave it .
Looks like a better frisbee than an airplane.
Old 06-06-2004 | 10:00 PM
Ben Lanterman's Avatar
Default Not a delta
If you fill in the gap and think of it as one surface then the aero center will be at 25% of the local chord. For stability you put the CG in front of that.
Think of it as two separate wing surfaces. The forward wing will have a aero center at its 25% chord and the aft wing have its aero center at its 25% chord. If the wings are the same size then the net aero center is basically half way between the two wings. The CG will need to be in front of that.
Based on the relative areas of each wing the aero center will shift forward or aft a little.
There is a lot of difference in the CG for the two approaches.
Old 06-07-2004 | 09:18 AM
Spaceclam's Avatar
noseheavy planes will fly again.
