Go Back  RCU Forums > RC Airplanes > Aerodynamics
 wing alignment >
wing alignment
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
wing alignment
Old 10-12-2004 | 06:58 PM
Default wing alignment
have katana 73in with wing tips not equal to horz stab..about 1/4 inch difference..what problems will be encountered? This is not correctable..is plane worth completing?
Old 10-12-2004 | 07:52 PM
Dago Red's Avatar
Default RE: wing alignment
which is off, the horizontal stab or wing? if its the stab, use shims and flatten it out. I had a plane i designed that had the same problem, about the same amount off to, i didnt fix it. The plane flew great. I was told it shouldnt casue any problems, but maybe tip stall that way?
Old 10-13-2004 | 12:44 PM
h stab is ok but distance from h stab tip to wing tips varies by 1/4 in..ie the wing is off..what say guys?
Old 10-13-2004 | 01:06 PM
Dago Red's Avatar
i dont see why you cant use shims to raise the wing level, i have performed this before. Now if this Kantana has plug in, well, i think your out of luck.
Old 10-13-2004 | 04:42 PM
Ben Lanterman's Avatar
Are you taking the distance from the stab tip to the wing tip trailing edge as looking from the top (1)
looking from the front about the horizontal tail angular orientation with respect to the wing? (2)
(1) won't matter much, (2) can be taken care of with some small balsa shims.
Old 10-14-2004 | 08:56 AM
thanks....issue no 1...will go ahead...really appreciate the input
