Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Flaps?
Old 07-18-2005 | 12:03 PM
coolbean's Avatar
Default Flaps?
I have a hobbico spectrum. I love the plane, it is very acrobatic and very fast. Almost too fast. it takes a long time to bleed off speed and stalls rather quickly. Since I'm landing on some pretty rough grass it can be a little hair raising. I have already had to change the landing gear location (the gear is notoriously weak on this model anyway), and i've gone to bigger wheels.
It does have separate servos for the ailerons. Currently this is going through a Y connection and into one channel on the receiver. But it would be very easy with my radio to make them flaperons.
Is this advisable? Would it really help? and what kind of flight characteristics can I expect?
Old 07-18-2005 | 12:19 PM
Default RE: Flaps?
I think flaperons would depend on the size of the ailerons to actually work, it would probably make a difference in flight characteristics
Old 07-18-2005 | 12:22 PM
exeter_acres's Avatar
Default RE: Flaps?
what prop are you using?
Old 07-18-2005 | 12:30 PM
coolbean's Avatar
Default RE: Flaps?
I have an os .46 FX spinning an APC 11X8
Old 07-18-2005 | 12:38 PM
Default RE: Flaps?
The 11-8 is a bit stiff for an FX (it's a 60-size prop). Try an APC 12-4 -- you will lose a chunk of speed at both ends, plus gain a ton of vertical. Top level speed will be ~ 60 mph & the landing speed will fall off a lot -- you probably wont need flaps.
Old 07-18-2005 | 12:40 PM
Default RE: Flaps?
yep... agreed... I use the 12.25 x 3.75 and love it... plenty of get up and go... but slows down nicely
Old 07-18-2005 | 07:26 PM
Default RE: Flaps?
ORIGINAL: coolbean
Flaperons can aid in lowering landing speeds, BUT.. when deflected a lot, the drag they add is also a lot, and the nose must kept down, because of the two problems which flaperons create. Tip stalls first. Dropping the trailing edge reduces the angle of attack at stall, the plane will stall sooner than it will without the flaperons.
At large deflcetions, with a roll command, the aileron that should go down can't.. it's already down. The other aileron goes up, which reduces the drap on that side a LOT. The down aileron drag then pulls the nose -opposite- to the commanded direction. which is VERY disorienting when first experienced.
I'd recommed going to a flatter pitch prop, as britbrat. I fly a Morris Top Cap with the OS 46 FX, and it's quite happy with a Zinger 12x4.
Old 07-18-2005 | 08:03 PM
coolbean's Avatar
Default RE: Flaps?
Picked up an APC 12x4 on my way home from work. All I have to say is WOW! I knew how fast that engine could run, the first prop i had on there was a 10X7 and it just screamed. But now I know how hard it can pull. I havn't had a chance to fly it yet so I don't know if it has slowed down the landings, but can't wait to get to the field and see how fast this thing can go straight up!
Old 07-18-2005 | 10:43 PM
Default RE: Flaps?
The larger prop puts the rpm closer to the torque peak of the motor, where it really shines.
The small prop is for flying very fast, but without the vertical from a standstill.
