Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Pusher design >
Pusher design
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Pusher design
Old 10-14-2005 | 05:44 PM
Jim Finn's Avatar
Default Pusher design
What is the advantage of a pusher prop arrangement on a full size B-36 For example? Why was it designed that way?
Old 10-14-2005 | 06:24 PM
Default RE: Pusher design
It may have been for better engine cooling. That was a huge problem with the B-29. It would also clean up the leading edge of the wing. Ever see the original B-36 landing gear? Three giant tires. They still have one at Wright-Patterson in Ohio.
Old 10-14-2005 | 07:24 PM
ORIGINAL: Jim Finn
At least part of the reason for mounting the engines "backwards" was for streamlining. The leading edge of the Peacemaker was swept, and the engines were 28 cylinder R-4360's with 3800 hp each. For the propeller to clear the leading edge, the engines would have had to be mounted forward of the leading edge, much like the B-29's, which is an aerodynamically dirty design. The trailing edge is almost perpendicular to the fuse, so no problem with prop clearance. The wing section of the B-36 was so large that there was an accessway inside the wing that the flight engineer could reach the engines through.
I always thought the B-52 was a big airplane, saw many on the ramps whenever we flew into Carswell, but the B-36 absolutely dwarfs them.
Old 10-16-2005 | 04:54 PM
Jim Finn's Avatar
Thank you...guys. I understand why now. Makes good sense.
