Go Back  RCU Forums > RC Airplanes > Aerodynamics
 To B or not to B, that is the question >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 03-04-2006 | 05:45 PM
flybye33's Avatar
Default To B or not to B, that is the question
I have always believed that an all moving stab should be (mass) balanced.
Recently, after reading the instructions of the Skymaster F15 Turbine model, the instructions call out for no mass balancing.
Instead the use of a very high torque servo is specified ?
Goes against all I know about aerodydamics, but maybe they don't want extra weight at the aft end ?
Your thoughts please.
Old 03-04-2006 | 06:54 PM
B.L.E.'s Avatar
Default RE: To B or not to B, that is the question
It sure can't hurt to mass balance the stab. If the stab's center of mass is forward of it's mean aerodynamic center, it probably will not flutter. Helicopter rotors often have weighted leading edges of the blades for this very reason. The higher the airspeed, the more important it is for each part of the plane to be aerodynamically stable on its own as well as having the entire plane being stable.
If the stab's pivot point should also be slightly ahead of the M.A.C. or control snatch can occur.
Old 03-13-2006 | 01:16 AM
It might be nice to pivot the surface at the 1/4 cord, as at this point the tail pitching moment sum is equal to zero for any angle of attack.
