Go Back  RCU Forums > RC Airplanes > Aerodynamics
 AIRFOIL CONVERTER NEEDED >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 11-04-2006 | 12:00 AM
Default AIRFOIL CONVERTER NEEDED
Can someone point me to one of those freeware airfoil coordinate converters.
I have a few airfoils in -.dat, -.air and -.cor formats which need to be converted from one format over to another, such that they can be used with different softwares.
I would perfer the converter to work within a DOS format.
Wm.
Old 11-04-2006 | 12:12 AM
Default RE: AIRFOIL CONVERTER NEEDED
What program created them? Did you look at the files to see if you can extarct the data? You may be able to get it into Excel to modify it and then save as a Text file so some of the common Drawing could import it.
The .Air and .Cor sound like they may be a special format that only the software that created them can use. Could be wrong.
If you could post a sample of each, you might stand a better chance of getting what you need.
Don
Old 11-11-2006 | 10:01 PM
My Feedback: (8)
Actually Profili 2.0 should conver the .cor and .dat files.
[link=http://www.profili2.com]Profili 2.0[/link]
