Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Balancing Point >
Balancing Point
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Balancing Point
Old 11-16-2006 | 10:25 PM
My Feedback: (19)
Default Balancing Point
On the p51 60 Mustang the specs say the Center Balancing Point is 4 3/4 in.from the leading edge.Is this at the fusalage
or the wing tip.Is there a rule of thumb or a formula for balansing an aircraft.I am using a magnum xl 90 4/s inverted.I did the measurments
as they said...and that baby is really nose heavy.Do I balance with a full tank of gas or what.
Thanky Much.
Pappy
Old 11-17-2006 | 12:17 AM
littlecrankshaf's Avatar
My Feedback: (58)
Default RE: Balancing Point
No fuel in tank. Unless specified else wise the standard CG location would be measured near the fuse.
Old 11-17-2006 | 04:29 AM
And if the wheels go up and back, then balance with the wheels up as well. Scale models fly better with the balance point closer to 20% MAC than 30%.
Evan
Old 11-17-2006 | 08:59 AM
My Feedback: (19)
Many Thanks You Guys....The kit I bought is very very bad on specs.
Thanks again..Be Nice Be Safe Be Loved
Pappy
